JonnyBlaze
SV600. Can I use black rtv on the valve cover INSTEAD of a new gasket like on Briggs engines or do I need to get a new gasket?
Good advice. Thanks.Only if you never want to remove the valve cover without ruining it. The design of that cover is different than Briggs and if you go with a liquid gasket when you try to remove the cover later it will not come off easily. Seen it more than once and have had to replace the cover.
