Honda GXV120 serial number location
slow_runner
Honda GXV120 engine build number location
Today I attempted to find the engine build numbers on my two spare GXV120 motors.
I checked out the Honda handbook and saw the location indicated.
So, outside to the shed and dragged out the Swift with the Honda. I removed the cover and looked about, then off came the fuel tank. Nothing.
Can anyone help me out here; where is the engine number located? Or have I missed the bleeding obvious?:biggrin:
edit: title description
Re: Honda GXV120 engine build number location
Different location for my GCV190, but it is installed with small indentations. Might try something to highlight that area with a black agent to look for these as i had to look real hard to find on my engine, and I was looking right at the spot my manual said to see.
Hello wdwalsh56, thanks.
I took a few images with my phone and zoomed in on them to find a number to the right of the fuel tank. It is very faint.
I'll take your advice and highlight it, then take a clean shot of it.
After using the zoom function and the optivisor, I found this number behind and to the right of the fuel tank.
I assume it is the engine number??
This particular GXV is mounted on a slightly battered Australian SupaSwift.
Bert, you would be familiar with the SupaSwift, yes?
It was given to me years ago by Darren as rebuilt, but a smoker. It has sat in my open lean-to for a long time yet still feels good on the pull chord and has spark.
When I disconnected the fuel tank and set it to one side I found what appeared to be oil on the chassis.
I wiped that up with a rag to find it was reddish; auto trans fluid it seems. Strange...
Darren owned a brake shop and I am guessing here but it would appear that a disgruntled employee had nobbled the motor by adding ATF into the fuel tank. Now, all that time later the fuel has evaporated, leaving the ATF behind. Plausable??
Darren certainly would not have done this himself:rolleyes:
