HiTekRedNeck
- Mar 31, 2018
- 10
Hello,
I have a hair pulling no spark situation. Motor turns fast enough, so I assume this should be sparking.
1-Replaced magneto, It was a little different but should have worked.
2-pulled flywheel to check stator and wiring
3-unplugged kill wire at magneto still no start
4-checked all grounds and switches, which I believe wont even allow starter to turn if theres a problem.
5-Air gap is .012
5-Air gap is .012
