I own a Mantis cultivator model SV-2AE and trying to find a replacement coil part number 15660109820 which is showing no longer available. Is there anything that will replace it? It sets on bottom of cultivator separate from the flywheel and coil exciter.
Thanks for that info. I can't find the coil anywhere. It did spark a couple of times and engine did fire, but now nothing. I'm not sure if it's the coil for the exciter coil. I've never owned anything with a separate exciter coil and not really sure how it works. Guess it doesn't matter as they're not made anymore either. I thought a coil worked or didn't so I'm not 100 percent sure it is the coil that's the issue. Thanks again.
