cruzenmike
I have an 18hp Vanguard, model, make, code 356777-0115-E1. I was running into an issue with oil getting on my mower frame at the base of the engine without being able to identify the source. I removed the dipstick tube and found a partially flattened o-ring which I have replaced. Now the question is, am I missing another o-ring? One parts diagram shows that the dipstick tube has an o-ring at the top for the dipstick and one at the bottom where the tube enters the block (the one I replaced). A second diagram shows an o-ring that possibly sits in the block (oil gallery). When I removed the dipstick tube there was nothing sitting beneath it in the block. Am I missing something? Here are links to the two diagrams:
https://polr.partstree.com/v1/iplim...wdGlvbnMiO2E6MTp7czo1OiJ3aWR0aCI7aToxMDAwO319
- item 524 is what I replaced.
- Part 439 is the one I don't know if I need.
I appreciate your help.
Mike
Mike
