screamingeagle
- Nov 28, 2017
- 8
I have a Z445-48c mower with a 25hp Kawasaki and it is not firing like it should on the rear plug just once in a while. Now the first thing i done was clean the plug & re gaped it to 0.30, that didn't help so next I switched the plugs and the story was the same, so i figured the plug wasn't the problem. (note when the engine is running the rear plug will hit every now and then). So my theory is a bad connection or bad ignition coil or even maybe the air gap. I would appreciate any help or advice whether I am on the right track or not. Thanks
