hrdman2luv
 - Aug 23, 2014
- Threads
 - 62
 - 345
Poulan Pro 34cc.
Cleaned out the card (best I could) inside and out. Primer bulb wouldn't pop back out. Now, it cranks and runs good with the choke on. But once you release the choke half way, or give it some gas, it dies right away.
BTW, when it cranks, (choked) it a very high idle.
I've adjusted the highs & lows in probably every position from 1/2 turn out to 3. Sometimes the same amount on each. I've tried with with different amounts each. Regardless of how it's adjusted, it's exactly the same result.
Anyone ever have this problem?
