Retired Lawman
I have a Tiger Cat with the Kawasaki engine on it that has over 1600 hours on it and does not use oil.
Which engine?
But I need something that will cut tall thick grass...I have a 93 hp John Deere tractor I use for dragging big stuff..
A Tiger Cat with a Kawasaki gas engine would be either an FX691V or an FX730V depending on the deck size.
If torque is a better measure of ability to cut grass why are torque numbers not given?hp is just a measure of torque at a given rpm.
The 22hp Kawasaki motors on the Tiger Cats are pretty impressive with power and durability. The secret again though to cutting the bahia grass is the velocity deck. We have had people stop where we were cutting grass and get out and kick the trimmings off the top and just look and say, " I didn't believe it would cut like that until I saw it."
One quick not on that. YOU HAVE TO KEEP SHARP BLADES ON THEM TO DO THAT.
Many days when cutting like that we have changed blades the third time in a 10 or 11 hour day to accomplish this.
It would take me 10 - 11 hours just to change the blades 3 times on my Cheetah..I try to change them every couple of years...![]()
