Retired Lawman
- May 23, 2017
- 32
How could I find out the torque ratings of the Scag diesel and the Scag Briggs and Stratton Vanguard?
I might not be smart enough to understand all of the technical terms associated with this thread. I do know one thing. I cut 90 plus properties in South Alabama over a two week period. 95% plus of those properties are Bahia Grass or partial Bahia Grass. In July and August when the afternoon rains start and the nights stay in the 80's it is almost like you can hear the mess growing.
I see debate on here an other places as to what will cut it and what will not cut it.
I run Tiger Cat Scags with 52" decks and Kawasaki engines.
I have on several different occasions run Turf Tigers with 35 hp Vanguards and 61" decks on them.
I once ran ZD 326 Kubota mower before going to Scags.
I have found NOTHING that will cut Bahia Grass with a 52" Tiger Cat Scag. The 61" Turf Tiger will cut it but not like the Tiger Cat. Over the course of several hours the Tiger Cat will cut more acres of grass than the Turf Tiger because of the fact that the Turf Tiger has to run slower or it will leave stringers that the Tiger Cats don't leave.
I have run them in the same properties, side by side. I have run the Turf Tiger and put my operators on the Tiger Cats. Then I have taken the Turf Tiger and put an employee on the Tiger Cats. Regardless of which of us runs it we see the same results.
I ran a Tiger Cat in the same yards as the ZD 326 Kubota with a 60" Deck. I never could get it to cut any where close to as clean as the Tiger Cat. I ran it myself and I had my operators try it and swapped back.
I still have a ZG 222 Kubota that is useless to cut Bahia grass because you have to make double passes over the Bahia to get it cut.
As much grass as I cut I need a bigger decked mower. I am going to look hard at a 72" or 61" Cheeta this coming year. I do not know what the outcome of that will be yet.
Everybody seems to have an opinion on what will Bahia grass and what won't. That is my observation.
I have on Tiger Cat that is above the 1600 hour mark. The deck has been worn through and patched several times. Abused is not a strong enough word for what that mower has been through. It has been assaulted or molested. That better describes how it has been used and it goes daily with little down time.
If you want to spend money. Buy something else. If you want to cut grass get a Tiger Cat Scag.
Interesting...What is it about the Tiger Cat you think makes it superior to the Turf Tiger?
I often wish I could bale my bahia....I use the Cheetah with the 61" cutter and the larger Kawasaki engine..My only complaint is that I don't like the twittchiness of the controls..It is just too fast to suit me..More experienced operators might like it...
