hrdman2luv
I have an MTD manufactured craftsman engine (on a craftsman rider. 420 CC) I'm getting a lot of oil in the carburetor. Ever so often, puffs of white smoke. Loss of power in high grass and up hills. SO much so that it almost kills the engine.
The mower came in with a little too much oil in it. About 1/4" above full. Made adjustments to the valves. Sprayed quite a bit of seafoam spray into the carb. Cleaned the spark plug. Changed fuel filter. The air filter isn't new. It had a lot of dust in it, which I carefully blew out. There's a little bit of oil on the air filter. But just a small spot or two. The oil isn't getting that far up.
After running it, I shut it off and took the air filter off. There was so much smoke in it that you couldn't hardly see down in it.
Pull the dipstick, and no smoke coming from the crank case.
The only label on the engine.
