TGMcCallie
Model 20074 Engine Tecumseh LV1905EA will not restart after being cut off while engine is hot.
It starts perfectly while cold but will not restart after being cut off when it is Hot. You have to wait for the engine to cool off before it will start again.
You can cut if off before it gets hot and it starts fine.
I had it in the shop and they put in a new spark plug and I am sure they did not let it get hot and try to restart it because they did not fix the problem.
I took it back to them and they refused to work on it. They stated that a Tecumseh engine was a problem and did not want to work on it. There is nothing else mechanically wrong with this Toro Recycler mower other than it will not restart when hot. I purchased the mower in 2007.
I need any information about why this is happening.
This is my first post on this forum.
Thanks for any help.
