Boudreaux In Eunice La.
Please take a pic of how your measuring the shaft. Did you pull the coupler off to measure the shaft. ??
I looked up the replacement shaft and it does show a 1 and 15/16 length.
IL engine is correct on his recommendation. I do have a pressure pump engine and that that shaft is 1 and 7/16.
I also have 2 6.5 hp engines I forgot what they came off of but they are the same 1 and 15/16......
