chops
Yes a crack in something messes everything up. We had a BRAND NEW woman's hospital in Lafayette La. 6 months later they had to shut it down,,,,,,, Too many CRACKS in the place LMAO......
Ok seriously. You got the coupler off the engine Great.. Leave the other half on the pump.
From the base of the sump/crank cover to the end of the shaft, not the oil seal it is 2 and 5/8 ? I think you mentioned that.
A pic would be a great help here Mon Ami.
Wow that is 12,000 dollars worth of wood you done split.....
Yea the new VA they built 2 years ago is all cracking also.. no joke. Had a veteran buddie from Lafayette got a purple heart in Beirut Lebanon blown off of a D8 high track dozer. I was stationed in Gulfport Miss with him
Ill take a pic tomorrow in daylight but I did it the same as you did in the video.
I'm a cheap one I put central heat on for a month almost $300 bucks I put a wood stove in the bedroom and have a fireplace in the living room. 12 years I been burning wood I first started chopping pallets and using a mall to split then I got to old to keep up and bought the splitter .Hell woods free plus I even get paid to take the wood .Got about 4and half cord cut already but like to have 11-12 in case of a bad winter... Bon ton Roulay
