Spin Trimmer tb20cs. Will not start
romeroom
It has been running fine. I had a hard time starting it today, could not keep it running. Now it will not start.
One odd symptom: When I push the primer bulb in, it takes a very long time for it to come back out again.
Here is what I've done:
1. Checked all the lines. Clear
2. Checked the fuel filter. Seems clear, though I removed it to see if it made a difference.
3. The primer bulb has gas in it, but it doesn't sound like it is pushing gas into the carb. The bulb is in good shape.
Any suggestions would be great. Thanks.
A slow return of the primer indicates a blocked inlet line or filter.
Thanks for responding.
Prior to my post, I removed the filter that is in the gas tank and put the hose back in the gas tank. I then removed a hose going into the carburator and it squirted gas, seeming like it was presurized. I wonder if it is plugged somewhere in the carburetor.
What is the "inlet line"?
The inlet line is the one with the fuel filter attached. there is also an internal carb filter screen that gets clogged.
FWIW, the "primer bulb" is not really a primer at all. It's more of an "air purge" bulb. It does not force fuel into the carb throat like a 'traditional' primer bulb does on a 4 cycle engine. When you push, the air and/or fuel in the bulb gets ejected directly into the fuel tank. As the bulb comes back to its normal shape, it creates a vacuum and sucks fuel from the tank, through the fuel filter stone and into the bulb. A couple of presses and you end up with bulb full of fuel and when the engine vacuum draws in, it's getting fuel instead of air! I've experienced slow return of these bulbs, particularly when it's drawing in 100% fuel.
There is a host of things to look at when troubleshooting a 2 cycle engine. Given your description, I'd be pulling the carb and checking the screen to see if it is clean. You'll know it when you see it. I'd also go ahead and replace the gaskets and diaphragms. Gasket kits are cheap(less than $15) and since you've already pulled it apart, it makes sense to replace. It looks like the carb is a Walbro WT-827. If you haven't tinkered with 2 cycle carbs, go to the Walbro site. They have service manuals for all their 'series' of carbs, this one being the WT series. Parts lists too for each model. They also have some service videos, and good 'ole YouTube has a bunch as well.
Be careful not to blow the carb out with 100psi of air and I'd shy away from shooting carb cleaner through it as the internal check valves can be damaged. The gasket kit is a D20-WAT which is extremely common. The full rebuild kit is a K20-WAT which I would not recommend. These kits are used for many carbs and you will have a bunch of pieces left over as you'll only be using 4. You can pitch the rest!
A final caution if you decide to do this, pay attention as you pull the covers off the carb. On one side, the gasket goes against the carb body, and then the diaphragm(called the metering diaphragm). On the other side, the diaphragm(called the fuel pump diaphragm) goes against the carb body, and then the gasket. Things won't work too well if either of those are reversed!
Good Luck. If getting the carb in shape doesn't solve your problem, we can proceed to the next things to check!
Many, many thanks. So helpful. Bravo!!
I will not get to it again for a while, but post progress once I do.
