Deck uneven when set at high level.
anthonyk
HI i have a Husqvarna CTH 140 Twin 36" ride on.
When I set the height of the deck to a high level the deck is lower on the right hand side then the left by an inch or more. I have followed the instructions given in the manual on how to correctly set the level of the deck, but the problem is still there.
As I lower the height using the adjusting wheel it levels out correctly, but the higher I set it the cutting level its very uneven.
Any ideas. is it just a setting problem or could something be broken.
Also where can I get a footrest LH No 532 18 10-57
BlazNT
Do a web search for this part number 532181057. You will find it.
I would look for a broken part on the deck lift.
anthonyk
I have, very hard to get. Looking for a broken part will mean removing the deck. Best get to work.
Thanks
Check the discharge chute.
They can snag the deck.
Those rear discharge decks are a bit of a problem with that.
The intermediate chute comes apart then gets caught on a corner as the height changes
anthonyk
100% right, turns out a weld on the lever that rises and drops the deck was broke. Bit of a job getting it out but re-welded and back in again. Happy Days.
Thanks for feedback, still looking for footrest.
