CraftsmanOwner
- Jun 25, 2017
- 8
Well, the Sears tech came back out today and changed 3 mandrals, 3 EZChange bar blade holders (clamps that allow easy changing of the blades with out tools), and took off the valve cover to apply sealant (silicone) so that it works as a gasket and stops the oil leak. However, he refused to fix/change/replace the Plenum (spelling?) that directs outside air into the engine fan. He said that it was more of an ascetic (for looks) part and wasn't covered under the warranty. Hey, I tried though right? He did take the plastic cover off the top of the engine though to inspect the fan itself and to check for more oil leaks. He didn't find any, however I noticed the engine had lots of gunk, dirt, dust and grass buildup under the cover. So I asked him to leave the cover off and I would power wash it tomorrow at the local car wash. Just wanted to update everyone. I'm ok with the service today, and even though that part wasn't covered because it won't cause harm to the engine, at least my mind is at ease knowing that. It may be because I am not mechincally inclined, but at least I learned something today.
