Hi, I just got a pretty beat down lawn mower from a friend, that did not start. I am not an expert and English is not my native language so excuse me for probably using the wrong terms, but I hope you can understand, what I am saying.
I cleaned the Carburator replaced the Carburator gasket, the air filter, the primer (the original one had a big cut) and the spark plug. Now it starts flawlessly with the first pull, but after a few seconds it starts to stutter and seems to run louder, than it should. What could be the issue here? It runs fine right after startup, but after 4-6 seconds it starts stuttering. When I tighten the smaller of the two springs, the stuttering seems to be ******** a bit, but that seems to also increse the rpm in general and after 8 seconds it starts to stutter again non the less.
I would be happy for suggestions, because my friend can not afford a new lawn mower and I told her I would try to fix it.
The engine is a 158cc from the 500 series.
