hrdman2luv
- Aug 23, 2014
- 345
I have a basic Craftsman Lt1000. With a 21hp briggs intek V twin. OHV. Model 917-272463.
The problem is, I can't get any juice to the starter. I've checked all the safety switches. Key switch. Ground. I've replaced the solenoid with a new one.
But when I turn the key, I get nothing.
What am I missing?
Which wire goes from the key switch to the solenoid? That's the only thing I haven't checked so far. Other than checking to see if there is any power going to all four posts on the solenoid. And the only power I've found, was the one that goes directly to the battery. No click when I turn the key on.
Checking the key switch. I checked the continuity from the "S" & "B". And got a connection.
I'm thinking I'm overlooking something. Or maybe not checking something correctly.
What am I missing?
