TonyPrin
I buy non ethanol gas for my mowers.
The reason I buy non ethanol is because I'd always heard alcohol will absorb moisture in the air/tank and that's what causes phase separation. Not so much the the ethanol itself separates from the gasoline but when moisture is introduced to the mixture. But I'm not a petroleum expert.
Not this spring but spring of 2016, somehow water got into my lawnmower's tank over the winter. The only thing I could think of was I forgot to top the tank off before putting it up for the season. Then over the winter, condensation formed in the tank and the water sunk to the bottom. I blinded over two fuel filters. I ran all of this gas through one of those Mr. Funnels and it seemed to get rid of the water.
I still buy non ethanol though.
Clearly you're correct about the dangers of phase separation. Water (that is, moisture) is absorbed by ethanol. When it reaches the saturation point the mixture sinks to the bottom of the tank because it is heavier than the remaining gasoline. This can begin to occur in about 30 days and, over time, up to 100% of the ethanol can be pulled from the gasoline.
The ethanol / water mixture can be very harmful and even ruin an engine. In addition, the ethanol free gasoline can cause knocking.
Small engine fuel caps are vented. As a result, moisture (perhaps in the form of condensation) from the storage area can enter the fuel tank due to expansion and contraction during storage. The best ways to avoid this are by a) adding a stabilizer to the fuel and filling the tank, or b) running your equipment to dry.
