Non-ethanol gas in not available at the pump at all in some areas by law. It has to do with air pollution "non-attainment" zones.
I'm lucky. There's a feed store close to me that has non ethanol fuel. You can sure tell the difference in the color of it.
Or by it's nasty smell. Ethanol is a contaminant of gasoline and if it weren't for the Big Corn lobby and government subsidy, the market would have dried up for ethanol gas long ago.
As if it wasn't bad enough already, the bought-and-paid-for politicians are considering upping the content to 15%.
I'm not a proponent of ethanol blended gasoline, but want accuracy on the issue. There is no such thing today as a government subsidy related to ethanol. There had been a subsidy but it ended 6 years ago. Of course there are requirements under the Renewable Fuels Standard that result in ethanol blended gasoline which benefit corn growers by creating a market that wouldn't otherwise exist but that's not a subsidy.
Beyond that, it's important to note that ethanol and gasoline are comparable in price today so the cost of gasoline (mostly taxes, anyway) would be about the same with or without ethanol. The real cost of ethanol, though, is that it has substantially less energy content so we have to burn more of it per gallon than straight gasoline.
You're absolutely correct. Thanks for pointing out my error. I should have said cost rather than price. Clearly non-blended gasoline is more expensive but that's not because of production cost. Of course gasoline is a petroleum product that fluctuates with the value of oil so it's likely for gasoline to become substantially more expensive than ethanol if the $/barrel price increases.Then explain to me why pure gasoline is typically 30 cents per gallon more expensive than ethanol gas.
10% ethanol gas, referred to as E10 is an EPA standard. (Hopefully this doesn't lead to an EPA debate.) It means the gasoline contains approximately but no more than 10% ethanol and 90% or more gasoline. Approx. 97% of the gasoline sold in the USA is E10. E10 is available for all octanes. Interestingly, ethanol is a higher octane than gasoline so an 87 octane blend is actually created with less than 87 octane gasoline and over 87 octane ethanol.
Non-ethanol gasoline is sold in some gas stations but is available primarily in gallon or smaller sizes.
Fresh E10 is not harmful to fairly new vehicles and small engines but can be harmful to older ones. The biggest potential problem with ethanol is in small engines like lawn mowers that aren't used frequently. Over time, the ethanol separates from the gasoline in a process called phase separation. Phase separation can cause major damage to a small engine particularly during or after storage, which is why best practices exist.
The primary reason for the use of ethanol is to replace Methyl Tertiary Butyl Ether (MTBE) as an additive in gasoline due to environmental problems with it. MTBE replaced Tetraethyl Lead, also due to environmental problems. The soils along many roadsides are still contaminated by lead from the use of Tetraethyl Lead and a lot of groundwater is still contaminated with MTBE. It is very soluble and mobile in groundwater (compared to other gasoline components). In comparison, ethanol is much less toxic...I deliberately consumed some after work this evening and it made me feel good![]()
