The Daily Yardman Thread
Roger B
Re: MTD Yardman Transaxle Rebuild
I still have my Avanti and that reminds me, I need to run out and find a new car cover worthy of the ole girl's value to me. She is old, but, not dead and still draws looks from the fellas wherever I take her.
MaxView attachment 31560
MAX-MAN,
Sweet ride, but I "thought" the idea of having a 'fancy' automobile was to attract girls, not "fellas", but hey, whatever 'blows-yer-skirt-up' as they say...
Rog
Roger B
PLUMBING!!! I HATE PLUMBING..............
Plumbing: Holy crap, what a nightmare yesterday was! I got to my daughter's house at 2 PM, (they had been out all day) and her husband was right, one of the three sump pumps was making a horrible noise, like it had a hand full of rocks in the impeller. However, before I can relate this story, you need some background. Nobody on that road has a real cellar under their house, especially up where I built my house, due to ground water. There is a Spring that pours out across the beach at the bottom of the road and all that comes from a bed of fine sand that lays under a shallow hardpan. When I had my full cellar dug, I asked for a large sump hole - (it ended up being 24" in diameter and over 3-feet deep). . . . Knowing that water intrusion would be my biggest problem, I bought three pumps, two 1/3-HP submersibles and a 1,000 GPM 12 VDC bilge pump for emergencies when the power failed. All three pumps are discharged into the same 1-1/2" line that runs underground out to a road catchment basin. The two main (120 VAC) pumps that I originally installed lasted 19 years and were replaced by a company my daughter hired when one of them quit, (Just back on March 18, 2015!!! Mind you.)
So we disconnected everything and lifted the pump assembly out of the sump. We quickly determined that the 'quiet' pump was dead! The bearings were so shot the impeller was loose inside the pump housing. The noisy pump was right behind it, but it was obvious we needed to put the assembly back into the sump and pump water before the cellar flooded. This is the worse time of year due to high levels of ground water. When we tried to start the one functioning pump, IT failed!! Due to the way the three-legged "Y" was assembled, we could not disconnect the two main pumps and ended up hauling a-s-s to H.D. for an old fashioned stand-up sump pump. We bought their last 1/2 HP, 4,500 GPH pump and took the Turn Pike back to the house as my daughter had texted her husband asking us to hurry as she was now bailing water out of the sump with a 5 gallon bucket! We got there and did some quick plumbing work in order to just get the pump in the water and running. It started up, but it made a funny noise I didn't like and once we stopped it, it wouldn't start again!! We pulled it up and discovered that the impeller was hitting the top of the pump housing. By messing with it, I found the upper of two Allen screws in the shaft coupling was loose, so I forced the shaft down and retightened the Allen screws. Then it ran quietly and started every time.. After a few plumbing refinements we finally got the height correct so the float would work properly and I left their house five hours after arriving!
I HATE Plumbing!!!
Roger
Roger B
Re: Replies.....
..(ROMEX --BX cable) easier to work with but learning circuitry rules over again because NOW a WHITE wire has become a HOT or a FEED - Boobala
Boo,
Me thinks you had a brain-fart - In AC residential wiring, White is Neutral, Black is Hot! The only time a white wire can be Hot is when it is used as a switch leg, or has been 're-identified' (as in colored black or red.)
I wish you had been with me yesterday! I could have used anyone who knows more about plumbing than I do! Now I have to make up a rig that will allow me to reattach the battery powered bilge-pump for emergencies before they have one!!
What a mess!!!
Rog
Boobala
Re: Replies.....
Boo,
What a mess!!!
Rog
NO brain-fart .. if you used ROMEX or BX .....( I'm sure you have ) ... yes ...SOMETIMES ...you HAVE to use the white as a "color" ..
be it used as a feed for a switch (as in a 3way/4way (or more) situation ) yes we used color code tape on the white but you know that does'nt always stay there (specially when a DIY guy has been rootin around in there )MAN I could go on a story bout a house (nightmare)
that had at least 5...4ways ...in 2 adjoining rooms ... at least with pipe you could always color code the "travelers" the sw. legs and others..... got into some 3 phase for awhile ... Gray as a neutral !!! Glad all that sheet is behind me !! Glad we DON'T have "cellars" (we call em basements in FL.) when I was a kid growin up in Jersey... my dad had all kinds of headaches .. we owned & lived in a BIG rooming house with a HUGE cellar with a coal furnace ( for 3 stories ... my dad LOVED shoveling coal in THAT thing) guess that's why he switched to an oil burner model .....ALWAYS headaches ...that's why we moved to WONDERFUL, CHARMING, WARM, DELIGHTFUL, ENCHANTING ...ETC...ETC.. FLORIDA..As far as me plumbing ... I can handle PVC and some of this new
"PEX " plastic pipe ( love those "sharkbite" fittings ) but I have nightmares about pipes bursting or leaking inside a wall ... AHHHhhhgggghh
AND NO shoveling ...EVER AGAIN !! I gave up MY "spoon" when I went back to Aircraft .. I remember working on a sump-pump
in a SEWER "lift-station" THAT convinced me to go back to IRON-WORKING !!! SOoo glad I'm RETIRED ...!!! Now ... when do we get started on .... "the Battle of the BRIGGS carburetor " ...??????????????
NorthBama
Is it true plumbers do crack. I am so glad I took the electrician career (retired now). Too much sheet in a plumbing a career.
Boobala
NO...NO Bama ... Plumbers DON'T "do" crack ( at least we think not )...Plumbers HAVE..."crack in back" ...also better known as
"sheet-chute"...usually seen when they bend over to fix kitchen sink !!
Electrical work is simple.... 2 wires , hook it up.. 3 wires , screw it up.. 4 or more wires , blow it up !! NO PROBLEM !!!..:laughing:..:laughing:
NorthBama
HaHa good one Boo. Plumbers need to wear shirts like the young ladies are wearing these days.( Long tail in back)
I have had a few of those (OH SHEET) in my days with 480 volts 4 wires makes for a big Bang :shocked:
with some help we could make Ole Roger's post go for 500
I guess Roger too busy with the white stuff
Boobala
If you are trying to make this the thread with the most views, you will have to pass 366,449 and counting:
http://www.lawnmowerforum.com/showthread.php/6242-Name-that-mower-game
AS SGT SCHULTZ , of "Hogan's Hero's" would say..... Vee Haaaff vaaayys uff deal ink vitt pipple lik you !!
Yep thats a lot of views .. strange ..It started 5 ( FIVE ) years ago to the same day ..!! BUT 5 years
Almost 25,000 in 6 months is nothing to sneeze at ... and not being a "game" type participation thread either !!
Anyvaay... you vill be shot at sunrise ... by orders uff Col. Klink !! ..:laughing: ..:laughing: ..:laughing:
Roger B
More Replies
Sooo,,, No-Ba-Ma, you was a "elec-trician" too? What sort of work did you do? Residential or Commercial? We had a family company (started in 1955) and did residential, light commercial and marine.
Primer- I don't suppose we will ever top the views that post has. I hadn't seen it before.. Oh well, as the desiderata states, "there are always those who are greater and lesser than yourself.." Besides, Boo maybe able to 'take care' of that situation all by himself... http://mwkworks.com/desiderata.html
Quiet day yesterday. Spent the day straightening out my shop and doing little projects. Boo sent some sunshine and the temps soared up to 58*... Quite balmy.. Snow is melting like crazy...
I actually looked at the YARDMAN yesterday, I had to climb up on the running board in order to reach an empty box I needed.. I intend to run some Sea Foam through it first, hopefully that will cure whatever problems the carb is having.. Boo-Boo wants me to take it all apart, but I believe in trying the simplest method first...
Zero Bubble....
Rog
