Intek V Twin valve adjustment
sadiesbud17
Hi, new to forum. I am not a professional, but I am fairly competent on things mechanical. That being said,I hope this question does not show my ignorance-In the Intek Service Manual it is stated to adjust valves @ 1/4"(6 mm) past top dead center. My question-1/4" on flywheel travel or piston travel? Be kind with your responses
Thanks
Ron
Simple no fail way to adjust valves.
Turn flywheel so that one valve is open. Adjust the closed one.
Sent from my iPhone using LMF
I can send you a Service Manual for your engine IF you like, address below, put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
Thanks to all for responding, especially SeniorCitizen(Me too), you answered my specific question.
Again thanks all
Ron
3/8", 1/2" or even 3/4" beyond TDC will work too. The manufacturer just wants to make sure the cam is off of the compression relief bump. A drink straw is a safe tool to use when monitoring piston travel.
