hrdman2luv
- Aug 23, 2014
- 345
Briggs 10hp (283707) on an older model snapper riding mower (30" deck with the rectable steering wheel).
When I disconnect the kill wire, it starts and runs fine. When I reconnect the kill wire, it kills it. I can't see any bare wires. I've moved them all around, off any parts of the frame. Checked the the safety switches with a meter. And they're all fine as well.
The key switch has 4 wires total. One is separate from the main connector.
The coil is a basic one, One plug wire. And one connection for the kill wire.
Am I over looking something obvious? Do I need to check the key switch?
I was thinking about putting in toggle switch for the kill wire.
Any help would be great.
