Anyone consider oil other than the stated 5w-30 that Honda recommends? Example would be Rotella T6 or Amsoil oils?
Just curious if there's something better available.
Thanks!
For everything but snow blowers, Honda says to use SAE 10W-30.
Not true. The manual for my Honda mower with the GCV160 engine says 5W-30. I use the same Mobil 1 synthetic 5W-30 I use in my cars and Honda snow blower. Zero issues with it.
At the end of the day, 5W-30 or 10W-30 are similar oils once the mower is warmed-up. Full synthetic oil is far superior to any/all conventional motor oils and I use 5W-30 synthetic in all my 4-cycle equipment. In terms of which synthetic oil to choose, all full - not blend synthetic oils can easily handle small engines so I look at price with rebates.
bertsmobile1 said:Yes BUT
Water cooled car engine oils are not the same as AIR COOLED mower / Motorcycle oils
next
Mower oils should always be changed at the end of the mower season, before the mower gets laid up over winter.
The quality of the oil is pretty well insignificant, provided it is changed AT THE ENGINE MAKERS REQUIRED INTERVALS and not what is written on the side of the bottle.
Having said that a lot of people use the same oil in all their vehicles & impliments as it saves having 25 different types of oils hanging around which is fine, provided you change it regularly.
And this would mean by hours during the season and also at the end of the season.
