cruzenmike
- Feb 10, 2017
- Threads
- 60
- 859
When purchasing a lawn roller there are many sizes and weights to choose from. Setting aside ones that can be pushed or pulled by hand, what is a good size or weight roller for a homeowner with a riding mower? It all comes down to how many pounds per linear inch of roller in contact with ground. For example, a 18" x 48" poly roller loaded up with water weighs 420 lbs (according to manufacturer). With some simple math, you get 8.75 lbs per linear inch of ground being compacted. Now, I am not trying to dig too deep into this, but at what point is the rolling or roller for that matter, just not doing enough? I get that doing it when the ground is at its softest will likely yield the best results, but if you get to a point where you are making only 2-4 lbs per linear inch ground contact, how can it be doing any good? I ask because I paid last year to have my lawn rolled and to my surprise they used a machine typically used for rolling hot asphalt. The thing had to weigh a thousand pounds or more. Most of us do not have access to this type of equipment, not can pull a load that heavy with a riding mower. Please share your thoughts. Thank you.
