JDgreen
- May 14, 2010
- Threads
- 248
- 2,887
Rubber valve stem on my '04 Buick was leaking air, rather that drive 15 miles round trip and pay for gas and labor to install a $1 valve stem, I decided to do it myself.
First, mark the tire/rim so no rebalancing is necessary if you rotate the tire on the rim. Second, park your vehicle with a receiver hitch on a hard surface. I used an old hitch bar, a 2 foot long section of 2X4, and a 6 ton bottle jack to pop the bead loose as illustrated.
WARNING: Be sure the jack WILL NOT CONTACT THE RIM AT ANY TIME. Standing on the 2X4 while pumping the jack also adds more pressure to loosen the bead. Since this method only loosens one tire bead, after replacing the valve stem, I was easily able to reseat the bead using only a small electric air pump.
WARNING: DO NOT put fingers, toes, or other body parts near the rim while reinflating the tire and DO NOT EXCEED 40 PSI.
It's a simple as that. My cost: Half hour and a $1 valve stem. Their cost: $10 labor, $3 valve stem, plus your time and gas to go someplace to have it done.
