Blades Spindle problem
houstad
I have a MTD yard machine (MTD model 607) that I have owned from day 1. The other day I went to remove the blades and the entire bolt spun but the blade didn't move. I had the blade blocked as usual and used my 1/2 socket on a breaker bar that I use just for this purpose. I have removed the deck and cleaned it to get it ready for repairs. Before I get into things I thought I would ask your opinions on what to look for? Thanks all for your help.
Look at the other blade disassembled and if the blade drive looks like the one pictured, the one you can't get apart is shot. Buy a new assembly.
Take the pulley off so you can install it on the new spindle you buy.
I take my pulleys nuts off with a 2x4 impactor either impacting the end of a breaker bar or good long sturdy box wrench.
For safety I tether the wrench.
By far the best way is an impact gun.
Saves a lot of grief and skinned knuckles, ask me how I know!
No Don't!
Use an impact wrench (as mentioned earlier) either electric or pneumatic.... to get the pulley nut off ,then install 2 nuts on the shaft where pulley was.. locking 1 against the other, hold the bottom nut secure...
( wrench ) then use the impact to remove blade nut ... use anti-seize compound when installing nuts on the shaft ...next time around . :biggrin:
