The Daily Yardman Thread
Boobala
Re: MTD Yardman Transaxle Rebuild
Boo-Boo,
Ha! How do you know they aren't in on this with me?? Three Murrays - Three guys - split three ways!! You might be needing another safety net!!
Ro-ho-ho
Ha ... G'day mate... yee fergot mee Aussie buddy Trevor ( bert ) .... av yee?? Seems Trev azz me bak covered ...got some of Croc Dundees tricks n surprises in case ya guys be plannin detrimental n dastardly acts upon me !! Right Trev .?? Trev...?? .... TREV..??? HEEYYY TRREVVV !! ???
primerbulb120
Moderator
Re: NEW MURRAY MTD MOWER
I already have a Murray, so you don't need to worry about me. :laughing:
Of course, it's not much of a mower compared to yours. :rolleyes:
Roger B
Re: MTD MURRAY
Primer One-Two-Zero,
Welcome aboard! It's about time some of you guys that have been following this insanity chimed in! We need the input! We need more pictures! We need something that is related to lawnmowers to discuss! However, with that said, your lawn doesn't look very healthy! Looks more like typical Florida sand to me! If you have been mowing that spot... STOP!! It's good enough and you are going to ruin your blades if you keep it up!
You say you have Honda mowers.. we accept Honda mowers here, but it is nice that you have a Murray.. Boo-Boo will be happy..
Don't be a stranger! Y'all come back now, Y'hear?
Roger
Roger B
Boo-Boo,
I would like to point out to "Bert", that it was not 'I' who blurted his name all over the page.. It was YOU!! You may now need to seek succor elsewhere...
Roge
BlazNT
Have you seen my Murray. Im totally rebuilding it one day.
Now that is a Murray.
Roger B
AND .............. heres that MTD TransAxle RE-call Information I told you about sometime long ago ...
.........http://wemakeitsafer.com/Cub-Cadet-MTD-Gold-and-Troy-Bilt-Lawn-Tractors-Recall-373052-854144
Boobala,
If you research the recall here is what it says: "What is the problem?
A drive gear in the lawn tractor's hydrostatic transaxle can fail causing brake failure, posing a crash hazard to consumers.
First I would wish anyone with those tractors luck in ID'ing the transaxle as we have discovered that the model numbers were changed numerous times.
What puzzles me is what gear is it that would fail and cause a loss of brakes? The transaxles I dealt with have a disc brake that is attached to the shifter shaft. You lock that shaft up and the axle can't turn unless a main drive gear failed.. You think they have started making those gears out of plastic?? I gotta go look at my transaxle pictures again...
Roger
Roger B
Boobala,
Roger
Yeah, I was right! Look at the following picture and you can see the brake is on the shifter shaft and locking that shaft up locks up the pinion gear that drives the main axle. Maybe those hydro axles are dramatically different inside?? Anybody got any pictures of them?
BlazNT
1984 and I want a show tractor. This model is a full mini tractor. I love the looks as a survivor but it has some issue you can not see. I want to take it to parades and stuff now that I'm getting older I figure I could attach a trailer and drag my grandson around in it.
