Wow, you guys are great! Lots of great info. The parts manual really will be a help. There really is a wide price range for the complete carb. Some of the prices seem pretty good considering the cost of the rebuild kit and solenoid. Here is what I ended up doing. I went to my local outdoor equiptment dealer and he order me a B&S rebuild kit ($46.50 + $10.00 shipping and handling). Great price on the kit, but the s&h is a little steep for a carb kit. I also was questioning if the solenoid might be part of the problem. The solenoid on this model seems to work in a way that it's extended, stopping the fuel flow until the ignition is turned on. It then retracts allowing fuel to enter. When I tested it on the 9 volt battery, nothing happened until I pushed the plunger in with my finger. It would stay in until I disconnected the battery. Seems like a faulty solenoid. Not totally convinced I had a great connection with the test wires, I reinstalled it in the connector on the tractor and turned the key. It snapped shut., but only 1 time. I kept trying, but nothing happened. Then I noticed that the tractor battery was almost dead. So I connected it to my truck battery and it worked every time. I guess it must be ok.
One thing that is a little confusing is reading on the internet that the sump being full of fuel (my problem and the reason for all this work) could be a bad solenoid. This seems odd because it's in the extended position when off (at least mine is) therefore not letting any or very little fuel into the carb. I must be missing something. In any case, I think I'll reinstall the same solenoid and move my shutoff closer to the carb. Worst case senerio would be the solinoid is indeed bad and I'll have to either relace it (expensive!) or clip it.
You guys have been great and I'll let you know the outcome when finished. Thanks.
Mike
Mike
