2010 Grasshopper 725 DT6
Wratliff4
Electrical problems,
I had 4 ground wires that came loose at the fuel filter now I have power all the time to my fuel solenoid, which burnt it to a crisp and I can't get my clutch to engage.
I have reconnected the ground wire, looked at all fuses, I am thinking the switch interlock module on the solenoid because it should have a 15 sec. time out from other post that I have read.
I am at wits end, anyone have any ideas
Thanks,
wratliff4
Sit down with a nice warm cup of your favourite beverage and hook up a globe to each of the wires, turn the ignition on then off and watch what happens.
Pull the blower housing and follow the ground wire from the ignition module then mark it,
This wire must only ever be open circuit or ground and never ever see voltage or you will cook the modules & they are expensive.
email grasshopper with your mower details and ask them for a wiring schematic usually they are good for that and it will make the job a whole lot easier.
