finfan1313
- Oct 24, 2016
- 14
I have a John Deere X320, and ever since I got it, I've had to jump start it almost every time I use it. I took the battery in, and the dealer told me it was fine (and that I'm out of warranty), and that I'd have to bring the whole mower in to get it fixed. I'm trying to do it myself, and am hoping to find what's causing the draw on the battery. I did some testing on the solenoid, and here's what I read at the battery and solenoid (4-pole). The black cable was removed from the battery to do these tests:
at battery: 12.32 Volts
Pole 1: from battery to solenoid - 12.32 Volts
Pole 2: purple wire pole at solenoid: 11.66 Volts
Pole 3: Other large nut with red wire: 11.66 Volts
I also checked at the starter, and it's getting 12.32
Generally, If I run the mower for an hour or so after a jump, and then I start it again right after I'm done, I can start it once. However if I wait a week, I get a few clicks, then it gets weaker and weaker until I get nothing, and the battery tests at about 3-4 volts before a jump. Could this be a bad solenoid? I checked the connection at the seat switch, which was dirty so I cleaned it, but the seat switch appears to work fine while I'm mowing. I'm sure it must be something fairly simple, but am trying to avoid spending a couple hundred $$ at the dealer.
Thank you!
Thank you!
