Blades What do you guys sharpen your blades with?
Grinder with flap wheel. Less agressive than your standard grinder disc. I don't balance tho... Shame on me. Spindles still alive tho.
For those of you that prefer a right angle grinder, try the Makita flex wheel. It'll grind circles around the older original wheels. This blade pictured was sharpened while I was setting in the comfort of my chair with the blade extended across my knee. The other picture is a piece of re-bar that needed threads on a stretcher for an outdoor chair repair. Solution for precision sizing. Grind it down while rotating it with a variable speed drill. Once again, the Makita flex wheel.
If you're gonna do it you may as well be comfortable and have fun doing it. :laughing:
