M man00 Active Member Sep 13, 2016 #1 While in neutral (arms extended out) the mower will ever so slowly move forwards. I did replace the pump idler spring when it broke.
M mechanic mark Lawn Pro Sep 14, 2016 #2 https://www.badboymowers.com/owners/mower-manuals see troubleshooting section after locating your manual http://www.searspartsdirect.com/rep...tral-control-on-a-zero-turn-riding-mower.html i know this is not your mower but may help Last edited: Sep 14, 2016
M man00 Active Member Sep 14, 2016 #3 mechanic mark said: https://www.badboymowers.com/owners/mower-manuals see troubleshooting section after locating your manual Click to expand... Thanks, but unless I over looked it, I didn't see anything in there that solves my issue.
M man00 Active Member Sep 14, 2016 #5 2013 Outlaw Extreme 5400 54" 852cc Kawasaki about 50 hour on the clock
Carscw Lawn Pro Sep 14, 2016 #6 Jack the back wheels up off the ground. There is a rod on the arms the run to the drives. With the engine running adjust the rods till the wheels stop moving. Should be able to use a 9/16s wrench.
M man00 Active Member Sep 14, 2016 #8 Carscw said: Do the brakes hold it still? Click to expand... yes brake holds I tried to adjust these to make them shorter..but there wasn't any adjustment left
