Engine Need a wiring diagram for ignition switch...
sillyboy
Hello All,
I need a wiring diagram for a ignition switch on a Sears rider model #917256524, switch #140301. I'm not sure if the new switch comes with a diagram, so I need to be ready. These are individual wires on this switch, and not sure if they will be long enough to pull out in the open. Did a search on this forum and found no results (could be me though). Found nothing online but the easy one plug with all the wires connected already (I wish).
Thanks in advance
sb
OK I'll look again at the downloaded manuals I have...
Thanks
sb
There it is!!! I had to download a user manual again, and found it. BTW what does "make" mean? :confused2:
Thank You
sb
