Puzzling occurrence
jekjr
Yesterday morning I was cutting grass with one of my Scag Tiger Cat mowers.
It was a very wet morning and the grass we were cutting had been cut a week to the day.
It was fairly heavy grass even though it was only a week away cut.
Anyway I smelled hot grease like a bearing getting hot. I looked down and raised the cover on the platform and the center bearing was smoking and it was the smell of a bearing overheating. Have smelled it hundreds of times because i was a maintenance mechanic in a paper mill for over 21 years. Smelled like the grease was very hot.
The mower has a little over 1000 hours on it and went out of warranty about a month ago. Just before warranty went out I had it in the dealer and they replaced all three spindles and bearings in the deck.
I took it back to the dealer yesterday. I went back yesterday afternoon and the mechanic said that he could find nothing wrong with the mower. He said that he removed the belts and checked for slack in the bearings on all three spindles and there was none. Nothing was binding or dragging or no noise when turning anything by hand. He said that he started the mower and engaged the deck and bypassed the switch and let it run for over an hour and nothing heated or smoked.
I ran that same mower 8 hours today and it ran flawless.
I have never seen this happen before.
Anybody got any thoughts on this one?
Cutting wet grass ?? ........ YOU must be made outa money !! That sure strains the equipment and sends it to an early junkyard !
I mow wet grass about everyday.My day starts at 6am long before the dew is gone. Have even mowed in the rain more than a few times. Back to original post.Maybe something was bound up and the heat n cooling cycle freed it up or it wore in.That kind of heat likely got the seal .Run it over grease it.Hope for the best.
Made of money ? No it's called we have to make the money.
some of us have no choice but to cut early morning dew or in the rain.
Here in southern Indiana the grass hasn't been dry for over 6 weeks.Temps in the 90's,humidity in the 70's℅ and rain every other day.Even with sunny conditions all day,with the high humidity,the grass never dries out.Could not imagine what the grass would look like if I waited for it to dry.(6 weeks so far and still waiting).Sometimes you have no choice..
I've seen wet grass get under the pulleys, smoke and burn from the friction.
I have also, and have had a stick drag on a turning part that started to burn.
When I lube the spindles, I look at the color of the venting grease to give me an indication of the bearing conditions. I have one spindle on my Tiger Cub that takes much more grease than the other two and spews out thin black grease when lubed. May need to replace this spindle in time. Am going to do a 50 hour lube of the machine today.
This is going to be my last mowing season, getting to old for this stuff, too dry, hot and dusty for this old man to deal with. I'll continue to do my own place and my church properties. I gave up snow removal a few years back and I don't miss any of it!!!!
It looks so pretty coming out the shoot. Water and grass being thrown with the little rainbow every once and a while,
If we did not cut wet grass we would not have cut grass here in about 6 weeks atleast and the grass would be waist high.
We run Scag Lawn Mowers and they can take it. That particular mower is 2 years old and has over 1000 hours on it. I have another one that will be 2 years old in April and it will have more than that on it by then as well.
We have to buy goo d equipment and run the hide off of it to make a living.
