I have a 2000 Snapper HiVac, model P216012 with a tired Briggs 6.0 consumer engine. I want to repower with the Honda GXV160, and see there are several different variants of that engine. I found one at Northern Tool, (GXV-160-UH2-A12) for $369, but it has a tappered 1 > 7/8 shaft. The GXV that Snapper is using is part: GXV-160-UH2-A1AS-649061 and comes on the commercial push mowers that Snapper sells and has a straight 7/8 in shaft. The A1AS will cost me about $100 more as I have to get that thru a dealer. For the guys that have done this conversion, which model of the GXV160 did you use?
I've read the other threads on this, but did not want to hijack with questions directly related to my project....
Northern Tool: http://www.northerntool.com/shop/to...&type=search&gclid=CIHvq5n59c0CFRRZhgodiewIYg
