Absolutely not, engine needs to breathe. First check oil level on dipstick if it's overfull & smells like gas you have a carburetor problem. If oil level is ok check spark plug by removing & inspecting visually. Check fuel cap vent for being open & free of dirt. If your mower is over a year old you need to adjust valves with engine cold. Post engine manufacturer as well as all numbers from engine data plate.
If the air filter is that badly choked, you would dissappear behind all that black smoke belching from the exhaust and the engine would sound like it had the choke on full.
The only thing that moves about when you push the mower is the oil in the sump, the fuel in the bowl and the fuel in the tank.
SO prime suspect is water in the fuel tank or carb bowl which sloshes when you move & gets sucked into carb.
No 2 suspect would be debris in the fuel tank, lines or bowl cutting off the fuel supply but that tends to have a lag after you push and worse when you stop pushing
No 3 suspect would be a loose wire / bare wire on the magneto cut out or as this is a push mower a control wire from the handle bars.
Overall poor performance could be a clogged filter, either type but neither should be sensative to movements.
No I did not miss your point, air filter should be replaced yearly unless you have dusty conditions then more often. Have you cleaned underside of deck & removed & inspected blade for cleaning, dressing up with a file & balancing blade. If your blade is buggered up & distorted it needs to be replaced. Model number is missing a number if B&S engine, six characters, model xxxxxx, type xxxx, trim xx & code number.
I just shot a video of trying to start it here: https://youtu.be/CGqgjrNFcaY
It doesnt want to start even at a stand still at the moment, as you can see!
Spec: http://imgur.com/rV5sEdX
Filter: http://imgur.com/7RevITe
Update: Switched out air filter after cleaning, adding oil, ect. and I managed to do about half my lawn until it started stalling yet again.![]()
I finally looked at your pictures. You need to remove the engine cover and clean under it. I bet you will fine grass and dirt under it.
