Blacktrain11
Greetings;
I have a Tecumseh (ohsk120 222019e) mounted on a wood spliter. The engine will run perfect for about 1 hour and 10 minutes. Then it will start to miss and sputter and it will start to back fire until it quits. If you let it sit for a half an hour you can start it up again and it will run perfect again for about 1 hour and 10 minutes and it will start to miss and sputter and start backfiring again until it quits. You can repeat this all day long and it does this over and over. Any help would be greatly appreciated. Thanks!!!
