Mad Mackie
Is that center sleve stepped to hold the baring's in place?
Or is there shoulder in the clutch for the bearings?
Hi John R,
I have no idea as I've never had one of these Ogura clutches apart yet. Several years ago I thought that I was having a clutch problem with my Tiger Cub so I bought a spare. Turns out that I had a ground problem on one of the terminals that are mounted on one of the engine mounting bolts.
I would think that there was at least one shoulder on the center sleeve to facilitate factory assembling, possibly two.
I'll look closer at my spare and check it out. There is an internal snap ring on the pulley bearing which is somewhat promising.
Lower torque clutches stake in the bearings and the stakes need to be ground off in order to both remove and install a new bearing, not easy to do without damaging the stamped sheet metal pulley and housing.
My Ingersoll 4018 garden tractor has a horizontal engine with the clutch on the front of the engine. I remove this clutch periodically, carefully lift the plastic seal and with a needle grease gun adapter, lube the bearings, but this is an easy job to do. This clutch gets overheated from hot engine cooling air and close location to the muffler. I have installed a heat shield on this machine, but I'm not convinced that it does much. I even bought special high temp ball bearing grease for this application.
