turbofiat124
Sorry for the late reply guys. I put the head back on my engine and adjusted the valve clearances to spec (.003"), I guess that's close enough. It fired right up, maybe faster than before.
I managed to mow about an acre or two during the first week of December. My wife said the rest of the yard did not need mulching so I gave up on the rest of the yard and parked it in my yard barn. I have not monitored the oil consumption but the engine never smoked.
So I'm going to assume the head gasket replacement was a success. I've replaced more than a couple of headgaskets on "old school" Fiat engines but never an OHC lawnmower engine.
If this engine fails or blows up, I'm replacing it with a Kohler engine like I did with my Snapper Hi-Vac mower. The same mower that the original B&S threw a rod through the blow when the connecting rod nuts vibrated loose.
Kohler engines seem to be bulletproof.
