Honda hrm215 cutting issues
Lebmet5
My hrm 215 has issues when the grass is thick or gets a little tall, the blades bog down, otherwise it still runs great, mzbb-6054758. Sxa 1994 model plastic deck 2 speed drive, if I dont cut every 3 days or so it takes twice as long to cut. Anyone have the same issues, if so what new parts were needed?
:welcome:
Sharp blades
Hmmmm. I'd check your valve clearance. As the rocker arms wear, it's possible your valves aren't opening to specs. I know adjusting the valve clearance on 4 stroke model airplane engines makes a HUGE difference in power.
Jeff
Check idle and full throttle engine speed. You'll need a small gas engine tach
Idle (throttle set to SLOW, blade control lever RELEASED) should be 1,700 +/- 150 rpm
Full throttle (throttle set to FAST, blade control lever ENGAGED) should be 3,150 — 3,300 rpm
If not to spec, adjust throttle cable, governor linkage, clean/replace carburetor, check engine compression, new spark plug, the basics...
Thanks, checked the rpms and adjusted, now is cutting a lot better. Best 22 year old mower in the county
