village7959
Hi all, we have an echo srm 3800 which we have had for a while now. Here lately, just after using it for 5-10 minutes, the gear box, not sure of the proper term for it, on the end of the shaft will get extremely hot. So hot, you can't use string or it will melt together and not feed out. After we found out it was doing this, we bought a new gear box and the same thing still happens. We bought a metal blade head for it since the string would not work but as I was using it today, and not for a long period of time, it got so hot, the whole head came off. The nut that holds it on was still attached, it just got so hot that it melted the plastic head around the nut.
I took the gear box off and can not find anything wrong with it, it has plenty of grease in it and in the shaft as well. It has a grease fitting on it and it gets greased periodically.
I hate to go out and buy a new one as I have a feeling it will have all kinds of emission crap on it and not run as good or last as long as this one. We do need a big one since we do cut some heavy stuff with it.
