Kohler 25 HP V-twin Brief Loss of Power
jakesmurray
This engine is on a 48" Craftsman GT5000 garden tractor. While mowing, it will lower the RPMs and lose a little power for about 5 seconds, then ramp right back up to full throttle. The mower still cuts and drives when it does this, but it is a nuisance. It does it about every 5 minutes or so while mowing, and it does not matter if it is going up a slope, down a slope, or on level terrain. The engine has been completely serviced, new spark plugs, oil, oil filter, air filter, and fuel filter. It also had an accelerator pump gasket/diaphragm replaced in the carburetor, and at that time the carb was completely cleaned. Any help would be greatly appreciated. Thanks. :cool:
I am wondering if you are loosing spark on one cylinder for short periods of time.
jakesmurray
Ah, I hadn't thought of that. I wonder how I could check it the instant it acts up?
BlazNT
It is called "inline Spark Tester.
jakesmurray
That's probably something I need to invest in...
mcdonell
I would probably be thinking when did I last change the spark plugs, fuel and air filter.
mcdonell
2 months ago, right before the season began
Sorry I missed that in your original post.
It does sound like a fuel issue to me. I might see what a little Seafoam in the fuel would do. Also I might check the fuel cap vent.
I have a 4 yr old 48" Craftsman so I am interested to see what you find out.
Good luck.
jakesmurray
No problem, I'll update this thread with what I find... :thumbsup:
Dpmulvan
Does it do it right away or after motor warms up?
