Engine LT150 has no spark
Trooper
LT 150 has no spark. I have replaced the coil, still no spark. Took the ground wire off the coil, no spark. Put a coil tester on the plug wire and grounded the tester, no spark. I don't believe there are any bad safety switches. All the switches appear to work as usual. Isn't a fuel problem, because there is no spark. What have I missed. Also pulled the flywheel to see if the key was ok, it was.
The LT150 has a single cylinder Kohler CV426S in it. You might want to check out the ignition module which is built into the key switch.
As for me we have a very good John Deere dealer by us. What I have done in the pass I bring the old module or coil with me and they have a way to test them for me. They don't charge me for this service but I also buy a lot of parts from them.
