RhettWS
Hello,
While agonizing over what mower to purchase, the discharge opening on the Raptor SD deck was a detractor. I read several posts were individuals groused about it. For a number of reasons I purchased it anyway with the idea that I would work on the discharge fairly soon. The chute itself sticks out about 1/2 mile and prevents you from getting remotely close to anything. On my first mow I just used a bungee to hold it up. This weekend I took off the chute and modified the deck using Lexan to cover the big hole on top of the deck. Images are attached. For some reason they are in reverse order but I have them numbered for you to see.
I made a pattern with some poster board, cut the Lexan with tin snips, made a few small holes in the deck and voila. I had enough material to make two pieces so I did just to get a little added strength. Lexan is pretty tough material and I can trim or fiddle with until I finalize exactly what I want. I've not cut with it just yet but for now I have a see-through deck. :smile:
Thought some others might be interested in this.
