Snapper Zero-turn
John Billodeaux
The mower is five years old and has been in the shop often since the second year we've owned it. It operates about an hour, then starts making a grinding noise and soon after doesn't engage when the arms are pushed forward, especially the right wheel. When the thing cools down it's fine for another hour or so. The repair people can't locate the problem because they won't mow with it for 1-2 hours. After the last time it was in the shop I noticed the right arm has to be pushed a little ahead of the left for the mower to go in a straight line. It seems to me something on the right side is overheating causing the mower to quit moving forward. We tried mowing clockwise and that seems to help a little but eventually the machine does the same thing...begins grinding and stops a short time later.
I was going to try to adjust the arms thinking that might be part of the problem, but am still looking for the user's guide.
Any suggestions?
chance123
It sounds like one of the hydro pumps are about to go. As a shop owner I get these directly from "hydrogear" at a great $avings. I might even have some in stock. Were you using Mobile one 15W-50 oil in the hydro system? I am on vacation now but my computer says that I have 5 in stock.
edit:
Have you checked your hydro oil filter?
RobertNYoung
Re: Snapper 50" Zero-turn
Replaced 3 50" mower blades and to 2 belts center blade (PTO blade) cuts outside 2 (arbor blades) spin but don't cut? Belt is tight so when I turn center blade by hand outside blades turn? any ideas? Robert
logan01
. You need to start your on thread; not hijack this one.
Carscw
Slow down and start over.
I have no clue what you are asking.
