Absolutely yes needle bearings should be in all caps. Safety first, safety glasses & gloves. First remove grease fitting, then remove snap rings or spring clips at caps, you can use a hammer on driveshaft to drive u-joint & caps out. Remember to grease new u-joint.
725DT6 2010 PTO Shaft Clutch Assembly- Grasshopper Mower Parts- The Mower Shop, Inc.
The Mower Shop, Inc. - Detail1 - 121010 - 121010 ... Cross Bearing,,please note:this replacement bearing now comes from grasshopper without grease zerts - - The Mower Shop, Inc.
I haven't ran across any of that style in a mower. But I have changed them in ATV's and cars. You will have to remove the shaft. I have come across two different styles, molded plastic and snap rings that hold the bearings in place. I will make a guess you have the snap ring style. First remove the snap rings You will need to press out the old bearings and then remove the cross shaft. Then just reverse the progress to install the new joint. If you don't have a press I have done in the pass use a large punch and hammer. If by any chance you do have the molded plastic style you will need to burn out the plastic with a torch which I will say have it done.
