Toro GTS Wont run
graffspee
I have a Toro GTS 22" mower and I can not seem to figure out why it will not run. I have trouble shot the problem and have determined that there is no fuel getting to the combustion chamber. I have replaced the Carb , installed new Spark plug , and replaced the fuel line and it will still not start or when it does start will only run for a few minutes before it dies. Any Ideas?
Remove the fuel tank and clean the debris out of the bottom.
Check the out put hole for odstructions like a casting fin some times you need to VERY CAREFULLY run a drill file or rasp up there to clear up the hole.
That seemed to have worked. I cleaned the tank and it started right up....When I mow the yard again this weekend I will see how it does when it is run for a awhile but it is already running a lot better for the short time I just ran it...THANKS!!!!!
