lawn mower fanatic
The Z Masters aren't cheap. I'll bet the 3000 will be going for between 10 and 11K
Yeah and aren't the Exmarks a bit more expensive?
The Exmarks aren't really anymore expensive depending on the series you buy. The E series is the least expensive starting at around the 7K mark and up depending on the size of the deck and engine combination you buy.
Wow !!! $12K a unit. Should get a discount for buying 3.
Ric- Lil pricey indeed. But I guess you are right comparables are probably in about same price area. how big is the deck on the 2000 ?
I understand, for me going bigger than a 42", would just cause me more push mow work. And my push mow has no seat. :laughing:
Thanks for the info on the MR "Z"s
