hanyoukimura
- Jun 19, 2011
- 382
Thursday was a good day. I got the MTD finished and returned to its owner. Its a chocke system not a primer system, so it takes several pulls to get going when cold, but after that it'll start first pull and it runs great. All of the cables are in good shape and the drive system works too. The whole mower is in pretty good shape actually. Cleaned it up a bit before the sendoff.
I also finally got the Yard Man running. Narrowed the problem down to the carburetor after swapping the Craftsman's (which originally belonged to the Yard Man), after several attempts, I swapped out carburetors with another, and a few more cleanings later it was finally running. Took a while but now both it and the Craftsman start first pull and run really well. Just need to put the plastic shroud back on it, clean it up, and it'll be ready to go.
I was originally going to sell the Husqvarna for only $100 due to the nonfunctional drive system, but I listed it for $134 just to see if I got any bites. Within a few hours I had a hit, and its currently pending sale on Sunday.
